Re: iPod connected directly to FJ Jammer - Installation Instructions
Where to buy the Vais unit...
thanks
rjp previously said:
Here is a quick comparison of DICE and VAIS products; even if you don't want the VAIS, it does talk to some of the features available to each unit.
They may have fixed the issues with the DICE since I tried but, after 3 units, I was done with them. Thing would just not connect about 1/8 times; you would then have to turn the truck off and restart it. PITA if you were just running around town stopping a lot. After installing the VAIS, I've never looked back ... has worked 100% for nearly a year now. Big drawback with the VAIS unit is that you can't control the deck through the iPod; that is, you have to use the deck to navigate. I like to pick playlists and use random so not an issue for me ... is a problem for many though.
DICE vs. VAIS
ARB RR, UPG-1, OME H_Frt/M_Rear, ProComp 1069's, ProComp Xtrm AT305/65/17's, TRD Exhaust, AFE Cold Air Intake, Demello Sliders, BUD BUILT SKIDS
more to Follow...
