Old 10-09-2007, 03:27 PM   #1 (permalink)
RocKrawler
RocKrawler's Avatar
Member Number: 3158
Bilstein Low Cost Front Lift!
Bilstein now offers a height adjustable front shock that re-uses your factory coils and gives you up to 2.5" of lift for only $99 each! All Pro has these in stock and ready for immediate delivery, call and order yours now.
Bilsteins Promo material states:
Bilstein announces a new offering of height adjustable 5100 Series replacement shocks for
coilover design front suspension pickups. These new coilover style shocks utilize the vehicle’s
existing stock coil spring, with applications available for the 2004-06 Toyota Tundra and
Tacoma (AND FJ!), Ford F-150 and soon to include the Nissan Titan.
An extremely simple and affordable alternative to much higher priced systems, these new
5100 Height Adjustable shocks feature multiple snap-ring grooves on the body of the shock
to accommodate different spring seat positions, allowing height adjustments from 0" to 2.5",
depending on the application. By raising the spring seat position, you can alter the factory
rake to achieve a level front to rear ride height while accommodating up to 33" diameter tires.
The shocks feature vehicle specific split digressive valving and Bilstein’s industry leading high
gas pressure monotube technology.
As with all 5100 series shocks, these new height adjustable shocks provide superior
performance characteristics, feature bright Zinc plated bodies and come with a lifetime
aftermarket warranty. Bilstein also offers companion rear 5100 shocks with matched valving.
Bilstein designs and manufactures shocks for most cars, trucks and SUVs.
RocKrawler is offline   Reply With Quote
