Re: Slight clearance issue
That is a tough call. If you could find a small spacer (1" or less) I would go for the spacer. Not to sure on how the caliper is constructed in that area but I am sure there is excess material that could be cut off. But you really are playing with fire. I am think you could at lest take it down to the same height as were the numbers are stamped in at with out any problems.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
