Old 11-05-2007, 12:26 PM   #262 (permalink)
FJCryptographer
FJCryptographer's Avatar
Member Number: 15298
Re: turn the DRL's OFF!
CACressida previously said: View Post
If you pop the fuse box, theres a nice lil fuse that says DRL. All Toyotas havem. I'm keeping mine because I just found a new use for them. DRLs are dimmed compared to the headlights. So your using alot less power, but when your driving around in a lit city where you don't need the bright headlights, thats when the DRLs come in handy.
Does this really work? I've always heard this. BTW, where IS the fuse box on the FJ?
"Excessive dents and scratches under vehicle, skid plates, and body frame. Left front lower control arm dented. Vehicle shows heavy off road use. Both sides of body dented and heavily scratched. Aftermarket [rock rails] dented. Right mirror housing cracked and missing a piece. Windshield chipped. Tires have excessive wear w/ chunks of rubber missing from tread. Muffler smashed, hitting body of vehicle. Rear differential drain plug impacted, may be difficult to remove. Vehicle has after market lift kit and wench [sic]. Vehicle muffler has impact hole. All rims scratched and dented from impact. Left side roof rack bent. Roof dented at rack mount." –Toyota Tech Report on my FJ
FJCryptographer is offline   Reply With Quote
