so I wanted a temp lift, to just level the FJ out. Til I could afford a a real suspention lift. When I owned my Liberty I lifted the rear using the same rubber(automotive spring rated rubber) I used on the FJ. The rubber came from McMasters #8630K118 which is a 6"x6"x1" at $17.60ea., used two blocks one on each side. Using holesaws I cut out a donut out of the rubber for each side(sizes= 4-3/4" & 2-11/16") theres a pic of the donuts.
Had to rent spring compressors at $6.00 a day. Only needed a day.
With the 1' spacer I got about an 1-1/2" of lift that leveled the FJ.
Heres FJ after the lift.
So total cost of $41.20
. Now I need some OT at work so I can get MTs for the FJ.
07 FJ Cruiser - Sun Fusion (Yellow) 4x4 AT, 285-70/17 Good Year Wrangler MT/R's.
Home made Rock sliders,
Home made level lift.
Home made LCA skids, All-Pro extreme LCA links,
Home made High Lift Jack clamps, 4 KC
Daylighters,
Home made rear inside door rack,CB(cobra 19 & bandi mount,with 4' firestik, yakima load warrior w/extension, w/kayak and bike attachments.
