Old 05-13-2006, 10:35 PM   #14 (permalink)
SwissArmySuv
SwissArmySuv's Avatar
Member Number: 1693
FYI - Used the search and found some info on power outlets!
Wanted to add one myself and found very useful information here.
However, did not like (2) details:
1) tapping into the existing outlet gives you (2) outlets that don't work
when the key is off!
2) I did not want to sacrifice the little cubby hole for an outlet
with a plug sticking in it
Chose the console area for the new outlet and ran the wire to the fuse block.
Had to add about 10-12" onto the Radio Shack outlet to get there.
Included dimensions of outlet location in the pictures. Made sure I missed
molded ribs on the back side and missed the shifter. Left extra wire
under the console to make sure it did not catch the shifter. Used a meter
to find live tap points when key was off. Also used a 1 1/8" bit because
the recommended 1 3/32" is an odd size and I had a 1 1/8"! You will
need to file a small keyway for the anti-rotation rib on the outlet.
Drill your hole 3 5/8" from the front edge and .97" up from the bottom.
Note: The .97" dimension is important for (2) reasons:
Drill too high and you're into the radius on the console, drill too low
and you're into the overhang of the lower console piece.
Note: The top side of the first (3) open fuse ports on the bottom row are
hot when the key is off. I marked them with a red sharpie.
Aren't "sticky pads" cool!
Last piece of info:
I disconnected the battery for the project. By doing so you will need
to re-calibrate your compass when you are finished. I find that to calibrate
the compass, you need to drive in a "generous" circle, not a tight circle!
SwissArmySuv is offline   Reply With Quote
