Old 11-19-2007, 09:53 AM   #2 (permalink)
BMThiker
BMThiker's Avatar
Member Number: 3667
Re: Pre/Post run checklist??
When checking the CV boots, be sure to inspect the retaining clips. I had one go bad right at the weld and was able to replace it before it leaked all over the place. It looked like it was still holding but it popped off with little effort. I did a double wire wrap with one of those little wirebanding gizmos and it held up fine. http://www.clamptitetools.com/
All bolts! May not have to do everytime, but if you do alot of bouncing and jouncing, then check the torque of
Shock mount bolts
Lower control arm bolts
Diff/third member bolts
Also, somehow I tore the little ball joint dust cover boots on the upper A-arms (stock A-arms). The grease dries out and the ball joint sticks--making a popping sound when it articulates. Finally got it fixed last month.
All-Pro bumper, USB links, IFS skid, Extreme LCA links, LCA skids & Bandi mount
Bud Built trans skid/crossmember/gas skid
Metal-Tech red sliders
OME 886/895 springs & shocks
Super Swamper 34" LTBs
Warn 9.5xp/Masterpull line
Demello rear bumper
My PhotoBucket
TLCA #16667 Ga Cruisers - Black Sheep Upstate Cruisers - Safety Officer
Things are more like they are now than they have ever been. ~ Gerald Ford
BMThiker is offline   Reply With Quote
