Old 11-27-2007, 10:23 PM   #83 (permalink)
kurtfriedrich
kurtfriedrich's Avatar
Member Number: 14952
Re: FJ Alignment Specs
Ok, I read every post in this thread, and I think this is what the collective wisdom says (biased towards Doug from ToyTec's comments)
Camber left 0.0 Camber right 0.0 (get as close to 0 as possible)
Caster left 2.8 Caster right 2.8 +/- .5
or 2.6L 3.0R to compensate for road crown
But will end up on the low range because of the lift
Toe left 0.04 Toe right 0.04.
(camber is adjustable to 0 , You cannot Adjust Caster without sacrificing either toe, or Camber, on a vehicle that is lifted with stock control arms.)
Toyota Spec
FRONT Specification (Neg. Tolerance Pos. Tolerance)
Left Camber 0.15° (0.50° 0.50°)
Right Camber 0.15° (0.50° 0.50°)
Left Caster 2.82° (0.50° 0.50°)
Right Caster 2.82° (0.50° 0.50°)
Total Toe 0.08° (0.17° 0.17°)
Left SAI 12.35° (0.50° 0.50°)
Right SAI 12.35° (0.50° 0.50°)
Used to have an 08 Black Diamond, now my Traitor Rig
kurtfriedrich is offline   Reply With Quote
