Old 11-28-2007, 07:35 AM   #84 (permalink)
couver
Member Number: 4720
Re: FJ Alignment Specs
kurtfriedrich previously said: View Post
Caster left 2.8 Caster right 2.8 +/- .5
or 2.6L 3.0R to compensate for road crown
Based on my problems with right-hand pull, you do not want the caster 0.5 less than the left caster (-.5). You definitely want the right caster somewhere between 0.3 and 0.7 MORE than the left, whatever the actual numbers. If you get 2.6L and 3.0R as per your second option above, that should work.
Black Diamond 4x4 AT - 265/75/16 BFG MTs on TRD Rims, Demello Sliders, Bilstein 5100s (front)/"All-Terrain Package" Bilsteins (rear)
couver is offline   Reply With Quote
