Old 11-28-2007, 01:01 PM   #1 (permalink)
RocKrawler
RocKrawler's Avatar
Member Number: 3158
NOW AVAILABLE - FOX RACING SHOX 2.5" x 7/8 COIL-OVERS WITH REMOTE RESERVOIR!
In addition to our exclusive 2.0" Fox Coil Over Shox with compression adjuster remote reservoir, All-Pro Off Road is carrying the new Fox 2.5" Coil-Over Shox with remote reservoir - now available for the newer model Toyota off-road vehicles.
From the finish line of the Indy 500 to the deserts of Dakar, Fox coil-over shocks have proven themselves year after year. Now you can get these race proven shocks for your 03+ 4Runner, 05+ Tacoma, or 07+ FJ Cruiser.
Take one look at these coil-overs and you'll see why Fox is a leader in the off-road shock industry with unequaled quality. These shocks feature a hefty 2.5" body for more fluid capacity, eliminating fading.
Take one ride on these shocks and you'll feel the difference Fox Racing Shox makes. Enjoy a smooth, yet firm ride both on and off road.
These coil-overs are easy to install and come fully-assembled and pre-set to a 3" lift ride height, although adjustable. All hardware is included, as are the sway bar relocation plates with integrated die cut reservoir mounts.
Introductory Priced at $1,299/pair.
These top quality shocks feature:
7/8" Stainless Steel Heat Treated 17-4 H900, Hard Chrome Plated Shaft
High Flow Aluminum Piston
Smooth Bore Seamless Alloy Body with Clear Cadmium Plating
Tunable Velocity Sensitive Valving
Teflon Lined Heat Treated Alloy Steel Spherical Bearings
6061-T6 Billet Anodized Aluminum Body Caps & Eyelets
Nitrogen Gas Pressurized to 200 PSI
More pictures of these shocks installed coming soon. Click here All Pro Off Road for more info.
RocKrawler is offline   Reply With Quote
