Old 11-30-2007, 09:42 PM   #191 (permalink)
sonof40
sonof40's Avatar
Member Number: 11473
Re: Cobra 75 WXST and Bandi Mount Install
Mr R2FJ previously said: View Post
I just wanted to add a note here to make sure people do not over tighten the fire ring portion of the bandi mount. If you over tighten the bolt you can and probably will damage the ring. I did this and spent several hours on it before I figured out what was going on and I spoke to another guy today at a local meet that did exactly the same thing. Basically there is a solder join in the ring that breaks when you over tighten the main bolt. It twists it in such a way that will make you crazy trying to figure out your horrible SWR readings.
I know several people have mentioned that they "really had to crank down on it", but I just wanted to let people know that they shouldn't tighten down excessively unless they have to. If you properly remove the paint and get good metal to metal contact, normal torque on the mount should be fine.
Hope this helps others from repeating my mistakes.
I've found that a small amount of Permatex 67A dielectric grease makes a perfect ground without torquing too much.
Great install! Thanks bigbill and Bandi.
Steve
TLCA
Sleeping/Storage build: http://tinyurl.com/367bbw
Back Door Inside Latch: http://tinyurl.com/2jxwkk
sonof40 is online now   Reply With Quote
