Re: CLEAN 12v Fuse Block Accessory Install w/Pics
Thanks to your write up, I just finished the same wiring job. I located my blue sea fuse block in the same location. (My bracket didn't turn out quite as nice as yours, but I'm happy with it.)
The only things I did slightly different from your install were:
1) I added two 1/4" loops (used to secure cables against walls) to either side of my bracket at the top. These are used to help in routing wires.
2) I put heat shrink tubing on all connections
3) put some RTV on the rubber gasket where the wiring was run from the engine compartment into the cabin
4) I have not yet added a fuse to the wiring supplying power to the new fuse block.
Your excellent write up was my reference and made the task 1000% easier for me. Thank you!
Black Cherry "WartHog", DR suspension (front and rear), ICON UCA's, AFE CAI, ARB full length roof rack, Toyota Brush Guard & lights, Scuba Driver Mod, Baja 540c, body mount chop, Moto Metal 0951B wheels, Nitto Terra Grappler 285/70/17's
