Old 12-05-2007, 05:45 PM   #8 (permalink)
Fjamming
Fjamming's Avatar
Member Number: 6623
Re: Any news on the Marlin Crawler gears?
sbechtold previously said: View Post
I used a couple of heat guns to heat up the end of the tank nearest the transfer case. I then reshaped the front of the tank so that it would clear the transfer case. Reshaping the tank worked like a charm and I didn't lose any fuel capacity from the tank.
Sol, I found your old thread where you stated you were able to push back another 1.5 inch so it would clear. Do you think it would be possible to push back 3 inches as required by the Marlin gears? How much for the upgraded chromoly ouput shaft?
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline   Reply With Quote
