Old 12-06-2007, 09:42 PM   #64 (permalink)
Shadow-Warrior
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
Re: CLEAN 12v Fuse Block Accessory Install w/Pics
Aslan previously said: View Post
Thanks to your write up, I just finished the same wiring job. I located my blue sea fuse block in the same location. (My bracket didn't turn out quite as nice as yours, but I'm happy with it.)
The only things I did slightly different from your install were:
1) I added two 1/4" loops (used to secure cables against walls) to either side of my bracket at the top. These are used to help in routing wires.
2) I put heat shrink tubing on all connections
3) put some RTV on the rubber gasket where the wiring was run from the engine compartment into the cabin
4) I have not yet added a fuse to the wiring supplying power to the new fuse block.
Your excellent write up was my reference and made the task 1000% easier for me. Thank you!
Thanks
Can you run auxillary lights through this fuse block???
It depends on the type of lighting requirements, I am running IPF's they require you to go straight to the Battery for the power, they also have their own built in fuse block in the harness. If you plan on running fog's, or that type of lighting, that is how I would run it, right to this fuse block. I hope this helps.
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline   Reply With Quote
