Old 12-09-2007, 12:18 PM   #4 (permalink)
LandCruiserSteve
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: GPS: Overhead / Rear-View Mirror Installation Mod
CABLE ROUTING:
1 - Remove the driver side sun visor by unscrewing the two Phillips head screws.
2 - Remove the sun visor retaining clip by turning it 1/8th revolution to the left and pull straight out.
3 - Using a non-metalic pry device (i.e., plastic knife) to avoid scratching the plastic, remove the upper and lower covers from the driver side grab handle.
4 - Using a 10mm socket, remove the grab handle mounting screws and the grab handle itself.
5 - With your fingertips, gently pull downward and outward on the top of the plastic A-pillar cover.
6 - Remove the A-pillar cover completely.
7 - After you have fed your GPS cable and/or power cord up through the opening on the dash created by the removed A-pillar cover, route the cable(s) over to the opening by the rear-view mirror. Notch the headliner as necessary to allow the cable(s) to exit the headliner to the side of where the mirror and GPS will be mounted.
8 - Tuck the loose cable(s) up under the headliner with your fingertips.
9 - Take the remaining slack out of the cable(s) and secure them to the existing wires running down the A-pillar with cable ties.
10 - Replace the A-pillar cover, the grab handle, the sun visor and the sun visor retaining clip in the reverse order of removal. Then install the mirror/GPS mount (as per the instructions in post #1).
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
