Old 12-12-2007, 11:03 PM   #23 (permalink)
homedad
homedad's Avatar
Member Number: 10257
Re: Powertank fill ups?
Mr R2FJ previously said: View Post
Does that extra inch of metal housing in the regulator protect the hose from seeing liquid any more or less than it would if it was attached directly to the bottle valve? If that's a real issue you could certainly add another inch of metal tubing to it without getting an additional valve.
Most good quality airhose has a 1100+ burst, but the opperating pressure is much lower of course, so I could see how that might be a concern.
No....the Powertank set up in TWO vales....one for tank pressure and one for working pressure.....you can keep the line safe...yet still blow high volumes due to the better(non-freezing) valves.....
The Doc tried every other plan you can think of.....take his word for it...or his nerdness will kill you with type
I like Tator Tots...
http://www.fjccentral.com/techreflibrary.php
homedad is offline   Reply With Quote
