Old 12-27-2007, 12:09 AM   #268 (permalink)
jwp32750
Member Number: 16142
Re: Turn the DRL's OFF!
Regarding the disabling the DRL's, I've read all the recommmendations from cutting the wire under the DRL relay to disconnecting the gray connector near the driver's headlight. I was wondering, what happens if you just simply remove the DRL relay or DRL fuse or both?
Thanks,
Jim
jwp32750 is offline   Reply With Quote
