Old 12-19-2007, 04:04 PM   #7 (permalink)
FJ-Ollie
FJ-Ollie's Avatar
Member Number: 6685
Re: O&B Fab Front Swaybar Collar Mod
JoeUser previously said: View Post
Just to be clear, I can mount rings next to the stock retainer rings, right? Just to act as backups, in case the stock retainers fail?
If not, how easy is it to remove the stock rings? Will the sway bar have to be removed?
Yes you can. Some people have even used stainless hose clamps to reinforce factory collars.
The factory collars are like peuter. You can use a screwdriver as a chisel to split them and knock them off. It's pathetic how cheap they actually are.
"OLLIE" (AKA: FU-OLLIE)
K6JYB / "Head Butcher"
Check Out "OLLIE's" FJ:
FJ-Ollie is offline
