Radflo Shocks previously said:
These shocks are designed to replace the stock strut and the spacer.
On any coil over lift, you will only get a maximum of 3" of lift as you will run into problems with the cv joints binding and the boots tearing.
Glenn
How is it replacing the spacer? It would have to be a larger coilover seeing as the spacer is 5inches.
