Old 01-08-2008, 11:02 PM   #4 (permalink)
Nevada_FJ
Nevada_FJ's Avatar
Member Number: 3784
Re: All Pro Rear Bumper Install
I just put one on last month. Be careful with the cuts and you can always cut more. Test fit it a few times to make sure. The other issue I had was with the "self tapping bolts" pain in the back side. I lined it up and marked it but when I removed the bumper and drilled only 5 of the 8 holes worked for me on the refit. I know a few guys have not added the side bolts at all with no issues I also used a tap set rather than the self tapping bolts. If you had any questions please PM me and I will help as needed. Once cut there are still factory thin ovals cut outs in the plastic just above the All Pro bumper corners these made it look unfinished to me. I used some mastic tape (it is a rubber like tape in one inch strips that I cut to length to cover the holes). I got it at home depot I don't have pics but it finshed it off. Overall I am happy with the bumper fit I need to get a wheel spacer for the spare I have 285/70/17 and there is a slight rub at the bottom.
Good Luck
Nevada_FJ is offline   Reply With Quote
