Old 01-11-2008, 06:42 PM   #9 (permalink)
chichid65
chichid65's Avatar
Member Number: 15447
Re: If you have a driver side door rattle or squeek, listen up....
joecruiser previously said: View Post
I had a rattle that was driving me crazy! It sounded like it was coming from right behind my head, like from the rear door or maybe from the column that houses the seatbelt. I took it to the dealer and the heard it, but wanted the car for a few hours to do some testing. I envisioned them "testing" my vehicle by driving it around.... no thanks.
I went home. I had concluded that I could make it stop by applying pressure to the door panel. I was prepared to take the door panel off to see what I could find. Upon examination, I noticed that there is a plastic piece in the door jam, just below the metal "U" bolt that the door locks into when it closes. I'm not sure what this little plastic piece does, but it floats in nd out, depending on whether the door is open or not. Check it out, it is very loose. I jammed a piece of paper in, underneath it, and the noise has disappeared. So, I found the problem. Now I just need to find a more permanent fix. Hope this helps anyone with the "door rattle problem".
Man, I have complained about this from day one, nobody knows how to fix it. it's driving me nuts I have to turn my stereo on just so I won't hear it.
I will def. try this out and if it works come on over to my neck of the woods for a steak dinner!!!
"A Year Of Change"
2008 FJ-VooDoo blue/4x4/AT/GPS/K&N Air Filter/Revos/Up Pkg.2/VIP RS3200 Plus Security System/OEM Roof Rack/OEM Rock Rails/Tow Package/All Weather Floor Mats & Rear cargo Mat//Recovery strap.
chichid65 is offline   Reply With Quote
