Old 01-12-2008, 02:51 PM   #2 (permalink)
1911
1911's Avatar
Member Number: 4994
Re: Need advice on front strut install
rotorhed1 previously said: View Post
I'm in the middle of installing the ToyTec/OME lift. I got the old front strut out on one side and the new OME spring and shock assy with small spacer in on the top and the nuts started.
I've been trying for a couple of hours now to get the lower control arm to drop far enough down to get the lower shock bolt installed. I can't even get the shock to get near. Tried all sorts of pry bars, I even have a ratchet strap on the spring to compress it a bit.
Any ideas? Or am I doing something wrong? If I can't get this I'll end up putting the stock parts back on and taking it to a shop. I was quoted $500 for the job, really wanted to do it myself and spend the $ on a bumper.
Thanks
Two things:
1) Take out the two 19mm bolts that attach the lower A-arm to the spindle. This will make it easier to depress the lower A-arm. Be sure to torque them back to 100 ft-lbs when you are done, and some Loctite wouldn't hurt.
2) Get the longest pry bar you have and put the end under the lower A-arm pivot bolt and the bar itself over the top of the lower A-arm. You can then depress it way more than enough to get the coilover in and adjust the holes to line up so you can get the lower shock bolt through.
PM if you want and I'll give you my phone number and talk you through it. I've done that four times now, the latest yesterday.
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
KE5VTE
TLCA # 16550
1911 is offline   Reply With Quote
