Old 01-15-2008, 06:14 AM   #5 (permalink)
jhaydeno
jhaydeno's Avatar
Member Number: 14259
Re: Is there such a thing? (Drill bit to 1/2 drive)
FJamming, those things don't last too long and the torque isn't great for any small drill against old/large/rusted nuts. If you don't want an air wrench, you can cut the female end off a 3/8 or 1/2 extension and drop it into a heavy duty hammer drill. This method will not twist the skinny shaft on the part you've show, and is your best bet to remove stubborn nuts, skin off your knuckles, and, as a last resort, to crack your sockets! Maybe a bit overkill for some, but around here it gets the job done in a pinch on old tractors.
The ultimate in 4wd is green!
jhaydeno is offline   Reply With Quote
