Old 01-16-2008, 06:52 AM   #10 (permalink)
rutherk1
rutherk1's Avatar
Member Number: 3982
Send a message via Yahoo to rutherk1
Re: Does CO2 work well?
The only reason to use CO2 is that the molecules are larger and your tire will not go flat as fast.
At the consumer level, the only reason there is any hype about it is to get people in the tire stores.
CO2 + water = H2CO3. You get some carbonic acid but not very much without something as a Catalyst. Even at that its an extremely weak acid. Carbonic acid is component of your blood. Hey, you could fill your air compressor with blood.
Sure you can use it but regular air is just as good. Plus regular air is easy to find.
FJ's = possessive
FJs = plural
rutherk1 is offline   Reply With Quote
