Thread: Gear Help!!!!!
Old 01-16-2008, 07:27 AM   #5 (permalink)
WyoOtto
WyoOtto's Avatar
Member Number: 11698
Re: Gear Help!!!!!
DEWFPO previously said: View Post
If your not re-gearing for rock crawling, then your probably re-gearing to compensate for larger tires. The gear ratio, is often chosen to keep the engine in the same rpm band at the same speed as before. So, if the gears are chosen correctly (and they are available), you should be at about the same rpm at the same speed as before (with a corrected speedometer). In a perfect world that is.
So 4.13:1 gears should cause you to run the same rpms with the 35's as with the 32's. But I don't know of any that are available.
DEWFPO
Yea,
This is intriguing to me. If my calculations are correct (and often they are not), you would need a 38.6" tire to maintain the stock effective ratio with a 4.56 gears (the smallest aftermarket ratio available that I'm aware of). I haven't looked into it but someone has to be machining 4.10 gears for these rigs. If they're not, they should be....
Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, BMC, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Scuba Driver mods, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Custom Built Rear Shelf, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
WyoOtto is offline   Reply With Quote
