underthehood previously said:
I am a victim of the weak gears as well. My build date is 10/06. I didn't check the diff. build date. Mine sheared the teeth at 7500 miles. My new diff. build date is 07/25/07. I was locked and going up a rocky/loose dirt almost vertical incline. Some bouncing and then the harsh metal sound of broken gears. I dropped the drive shaft and had to drive 7 miles with the worst noise possible to reach civilization and have it towed to the dealer. They replaced the diff. and the axle housing. NO CHARGE. I hope the problem is gone....
I've added you to the list thanks for the info.
