Old 01-12-2008, 07:11 PM   #5 (permalink)
iCruiser
iCruiser's Avatar
Member Number: 479
Re: Experiment: Blackout door handle using Tundra handle covers
A visual installation of the Blacked Out Handle for those who need it (like myself) Added pictures to Sealevel's procedure.
1. Open Door, Identify Black Plasic plug on door jam and remove.
2. Loosen Torx fastener. The Torx fastener will not come out completely, or fall into the door, because it has a retainer clip which holds it in place.
3) You should now be able the pull the lock mechanism out.
4) Carefully take a small flat screw driver and pry the plastic lock cover off.
5) Slide the front part of the handle back and out.
6) Insert the new door handle into the opening of the door, slide it forward, and into position.
7) Snap the new lock cover onto the lock mechanism.
8) Insert the lock mechanism into the door, and tighten the Torx fastener
9) Front door handle swap complete!
Thanks NDA for such a great/simple mod!
T
TLC #17889
In service: March 25th, 2006
ARB Front Bumper, GOBI Stealth, Tuffy Console, Overhead ScanGuage w/HomeLink, Dirty Part's 2nd Battery Kit, Original Bandi Mount #11, OME 883, ARB Fridge, FJoel Battery Clamp
iCruiser is offline
