4 Low and A-Trac Does the Yellow Slipping car light come on
When in Low 4 and A-Trac, does the Yellow Slipping car light flash on when the A-Trac activates to make one of the wheels turn?
Example; When one wheel gets off the ground and the FJC needs to make it spin with the A-Trac, does the yellow "slipping FJC" light on the dash then flash?
I sure do not remember that happening previously. I recently had my rear differential repaired and I now noticed my Rear Sonars are not working correctly, when in reverse it just beeps all the time.
So I wonder if this A-trac light thing might be related to the rear Sonar problem.
TIA
FJCruisersFlorida.com and/or TBAJA.com
When you come to the fork in the road, go straight!
