Re: ALL Phase off road Rear diff skid (Group Buy)
We all do know that the rear axle was changed on the later '07 from the pre '07?
It could be all internals that were changed but Homedad had a write up here about Toyota replacing his rear diff after it went bad. He said it had a different part number and the breather was mounted differently. Before lemoning his '07 we inspected the new rear diff with with my later build '07 and they were the same. His '08 has the later one.
I doubt if there was an external change but if there is then depending on the FJ Mule that was used for test fitting the skid then some of us will have to do slight modifications and some won't. No fault from All Phase if this is the case.
Cheers,
