» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 01-17-2008, 12:13 AM   #17 (permalink)
PENROSE
Member Number: 16223
Re: Does CO2 work well?
rutherk1 previously said: View Post
The only reason to use CO2 is that the molecules are larger and your tire will not go flat as fast.
CO2 + water = H2CO3. You get some carbonic acid but not very much without something as a Catalyst. Even at that its an extremely weak acid. Carbonic acid is component of your blood. Hey, you could fill your air compressor with blood.
Sure you can use it but regular air is just as good. Plus regular air is easy to find.
I scored 1020 on my SAT's........am I ok? Or should I curl up into the fetile position now?
PENROSE is offline   Reply With Quote
