SkyKing previously said:
CO2 sounds like it will save me a lot of install work and thats real nice for me. Also, a lot less parts to fail on the road (or off).
If CO2 is okay to use, has anyone put nitrogen tanks in a truck. If ya fill your tires with it, the pressure should not change when its goes from hot to cold outside. Would think it would also work air tools (at about 1000 psi over CO2).
$.02 on this?
You can fill more tires with a 10lb CO2 then a 10lb nitrogen. That is a major reason to use CO2.
