» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 01-19-2008, 10:15 AM   #72 (permalink)
FJVP
FJVP's Avatar
Member Number: 8952
Re: Dual Battery Installation Write-Up - Pics
dvan previously said: View Post
Sorry FJVP you are a little off the money there.
Wire the batteries in series will double the voltage, just like batteries in a flashlight. But wire the battery in parrallel and you keep the voltage the same and double the amperage capacity of the battery system. This would be similar to when you jump start a car.
What you would want to do is tie the negative to the negative, positive to the positive. Gains you lots of added capacity however there would be no back up like in the other systems. You will be draining both batteries at the same time, but it is the simpliest wiring and no solenoid is required.
I stand corrected, I did not specify in series vs parrallel. Thanks for the correction.
Tim
SF Pre Runner - Flowmaster Series 50, Razors with BFG KO's, R.E.D Light Bar, PIAA 520's and PIAA 510 Fogs, AF HL Covers, Hella Dual Horns, Dirty Parts Dual Battery, aFe CAI, Vent Visors, Trail Gear Sliders, Demello Skid, AP 2" FOX Adj Res. Suspension, upper and lower Links, Shock Skids, Sway Bar Links, AP Airdam/light bar w/PIAA 510's, Coleman Rack Basket, Hi Lift, Spidertrax spacers, Tuffy Cargo Box and Lucrum Winch mount.
FJVP is offline   Reply With Quote
