Until someone does it and solves these issues:
Kansas Law Dog previously said:
Someone need to do some real homework on this one. There are eight issues as I see it.
1. Interference with the side air curtains.
2. Structural cross members that provide support because the length between the "A" and "C" pillars (no "B" pillar) is a longer distance than normal.
3. The roof is not as flat as most, has a definite convex shape.
4. The roof is ridged as opposed to a smooth surface (water tight sealing challenge).
5. NXT speakers placement.
6. Interference with existing wiring harness and how to provide adequate electric wiring for sunroof equipment.
7. Determine how much head room is sacrificed to install retractable sunroof gear (although there seems to be plenty of head room).
8. Finally, how to support the sunroof between the longitudinal structure that the roof rack bolts to.
I am very interested to see how long it takes Toyota to respond to an obvious demand for this option.
The answer is no one knows for sure. Who ever does it better post it and lay this issue to rest
(that was quoted from the first thread under the Similar threads at the bottom of the screen...in case you want to know where I got the from)
