layonnn previously said:
By "shifting" and the pictures i am guessing you mean that the end of the spring is not in the seat, correct? They could have been installed that way.
You could fix it yourself not too hard.
Lift the and put jack stands under the frame.
Unbol the bottom nut that holds on the shock.
Let the axle droop down and then the spring becomes loose.
You can then reposition the spring. Take maybe 30 minutes and save you some money if you have the tools.
If you lived here i would do it for you for 5 lbs of boiled crawfish.
thanks for the info and offer, I am planning on doing it myself with my friends help. Do you tihnk its weird if it was installed like that to just be doing it now after Ive had it one there for over a year? Also do you think it will be ok left like it is till this weekend?
