Old 01-24-2008, 12:31 AM   #14 (permalink)
JDMSi92
JDMSi92's Avatar
Member Number: 8828
Re: Vibration When Braking.. Out of Round Feel In Brake Pedal??
Do you happen to know if the dealer used an "on car lathe" or bench lathe? I have both at my shop and when you turn the rotor on the vehicle it is much more accurate machining process. You are basicly cutting the rotor to match the hub of the vehicle simulating how the rotor sits on the vehicle with the wheel bolted to it. Just something to consider if you run into a reaccurance.
My Location
JDMSi92 is offline   Reply With Quote
