Old 04-02-2007, 01:13 PM   #3 (permalink)
BMThiker
BMThiker's Avatar
Member Number: 3667
Re: HOW-TO: Remove the rear bumper fascia
I would EMPHASIZE that in step 6, you lift UP first and then away on the fascia of the bumper. If you try to simply pull straight out, you WILL break some of the top row clips (pictured as A in orig post). Lifting up on the fascia helps raise the catches above the retaining clips as you pull away from the body. Once you pop the single button clip from behind the wheel well area (pictured as B in orig post), you should be able to see the top row of clips holding the top edge. You will see what I mean then.
All-Pro bumper, USB links, IFS skid, Extreme LCA links, LCA skids & Bandi mount
Bud Built trans skid/crossmember/gas skid
Metal-Tech red sliders
OME 886/895 springs & shocks
Super Swamper 34" LTBs
Warn 9.5xp/Masterpull line
Demello rear bumper
My PhotoBucket
TLCA #16667 Ga Cruisers - Black Sheep Upstate Cruisers - Safety Officer
Things are more like they are now than they have ever been. ~ Gerald Ford
BMThiker is offline
