Re: New Fj's, Check Your Lug Nuts!!!!!!!!!!!!
attillahunley previously said:
I had the tires off of my FJ this last weekend.
The passenger side lug nuts were torqued somewhere close to 200 ft/lbs, had to really pull with a breaker bar, I broke my 21mm deep impact socket!!!!!!!!
The driver's side lugs nuts were somewhere between 35 ft/lbs and finger tight, I literally removed them with a 3/8" drive 6" ratchet handle with very little effort.......I was a few thousand miles from a problem, no doubt!!
Attilla
I checked my lug nuts and they were all 25-30 ft/lbs under spec. You would think Toyota would be careful about this as it could kill someone if the wheels were to fall off. GRRRRRRR!
2000 BMW MCoup
2007 Silver FJ AT
