Old 01-29-2008, 01:29 PM   #30 (permalink)
jhaydeno
jhaydeno's Avatar
Member Number: 14259
Re: Cheap tacoma switchs!!! $25 each
residualboulders previously said: View Post
jhaydeno, you have any pics of this switch you speak of? or know where they can be seen?
Residual, take a peek at these pics - If you need more info let me know. I haven't actually stuck it in a toyota hole, but it is exactly the same size and the blank off is the same piece as the toyota switches, atrac, vsc, reverse, etc. I can ohm out pins and map it if anyone wants to try one. Again, this is a TEC switch used in Honda / Isuzu for the last 8 or ten years.
ID:	19726  cheap-tacoma-switchs-25-each-switch-004-2-.jpg.jpg
ID:	19727  cheap-tacoma-switchs-25-each-switch-007-2-.jpg.jpg
The ultimate in 4wd is green!
jhaydeno is offline   Reply With Quote
