AceTechno previously said:
You can if you dont care about things like ease of control from the steering wheel, sound quality, meta data text display, etc. The signal comming out of the headphone jack has an EQ curve designed into its headphone amp that makes the FJ sound system sound kind of muddy. And no since sending a amplified EQ siginal into a low level input, that only causes distrtion. Comming off the dock connector to the back of the head unit is the cleanest way to do it for sound quality and for ease of use. It is the perfered way. The analog output in the dock connector is non-EQ'ed or amplified and bypasses a lot of other electronics in the siginal path that will lead to sound degragation and helps to "Restore" the original recording or data transfer from CD to computer to iPod to Stereo. Hope this helps.
I'm new to this but won't this 3.5mm to Dock Connector Audio Cable do the same thing as far as sound quality? Product Description
The iPod Compatible 3.5mm to Dock Connector Audio Cable allows you to play music from your iPod through your home or car stereo, computer, or notebook. The dock connector sends line level audio out from your iPod, providing better sound quality then when using the headphone jack. The dock connector also allows you to control the volume of your iPod through your stereo or computer instead of having to adjust the volume on the iPod. The lightweight construction makes it easy to take it anywhere you go. Works with iPod Nano 1st Generation, iPod Nano 2nd Generation (aluminum), iPod with color display, iPod with video, iPod Nano 3rd Generation (aluminum), iPod Classic, iPod Touch, iPod with click wheel, iPod 10GB, 15GB, 20GB, and iPod mini.
Amazon.com: Cables To Go - 35508 - 4ft iPod Dock Connector to 3.5mm Cable (White): Electronics
