» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 02-07-2008, 06:09 PM   #7 (permalink)
bartt
bartt's Avatar
Member Number: 1660
Re: Speaker Help Please
You guys are talking about what is called "the sensitivity" of the driver. The higher the sensitivity, the more volume is produced for the same input. It's measured in sound pressure level per watt at 1 meter. This is one of the factors that has to be matched properly in a multi-driver system. Just buying expensive speakers does not mean they will sound good.
The OP mentioned a buzzing sound. I have seen (heard) this when dirt gets into the spider and when the baskets are warped from being installed on non-flat surfaces.
It might also happen if you drive the amp into clipping (this chops the tops off the wave patterns when the output stage is overdriven). Thought usually this is sort of a popping sound, it's hard to describe. A bad impedence mismatch between the driver and the amp can aggravate this.
If you can hook up the drivers to a different HU, you can at least see where the problem is.
I know this didn't really go anywhere, but hope it helps..
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is offline   Reply With Quote
