» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 02-08-2008, 11:38 PM   #2 (permalink)
Stonewall
Member Number: 8380
Re: Need a little advice rigging up an fj
welcome to the form!
wow, it sounds like you are gonna have one bad a$$ ride. you should do a search on 3 inch vs 6 inch lift. there are pros and cons to both. 3 inch lift will give you a lower center of gravity which is important for serious off roading. the 6 inch will keep you body off the rocks and allow for bigger tires... plus it looks cool. If you really want a off road " purpose built" FJ, ask yourself if the 6 inch lift will allow you go where the 3 inch will not. my answer is probably not. plus the 6 inch does put some extra stress on parts that it wasn't built for. If you really want hard core off road go with a SAS (solid axle swap)
yes you can use either 31 or 33 inch tires with the 6 inch lift, but the smaller tires might look a little funny.
yes you can use a front arb locker with the rear elocker. but I have heard a few people say if you are going to use arb in the front you may as well replace the rear with arb also.
Sun Fusion, AT
265 M.T. MTZ
Pioneer AVIC D2
GOBI Stealth w/ ladder
BentUp sliders, skids, and bumpers
Stonewall is offline   Reply With Quote
