Old 02-12-2008, 12:23 AM   #6 (permalink)
mtrent3450
mtrent3450's Avatar
Member Number: 10303
Re: Lit Contura Switches Installed...
FJVP previously said: View Post
I just did that this past weekend, needed to add rooftop light switches. I put all stock switches on the bottom. I took out each switch and had to grind down the raised guides on them. I used a dremel with a small grinding stone. They are all interchangable now!
So was it easier to modify the switches instead of the console itself? I had not even thought about doing that. Thanks for the input.
mtrent3450 is offline   Reply With Quote
