Re: Need some feedback on my soon to be audio set up.
WickedCAS can custom build you a single 10" box to the specs of your sub. Also, as far as amps go, Eclipse makes the XA5000 that is 50x4 and 300x1 all at 4 ohms. Seen that one for about $300. Pretty much all I see doing a search for those specs if you just want to run one amplifier. You open yourself up to many more choices if you're willing to run two amps. As far as wiring up the sub, it depends on how many ohms the voice coils are to get what ohm load you're looking for. Also, depends on the amp if you're going 2 ohms or 4 ohms to get that 300 watts. Crutchfield has some pretty nice subwoofer wiring diagrams if you'd like to check them out.
