Old 10-13-2007, 09:37 PM   #2 (permalink)
LandCruiserSteve
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: Uniden CB Install - Pics
nevadaesh previously said: View Post
Do you have to take off the interior side mouldings to fish the coax? The power does not have to go to the battery?
No, I didn't have to remove the interior panels to fish the coax through, but I did pop a few corners of the plastic off their respective clips . . . just enough to squeeze my hand behind the panels to aid with the fishing. (A straighened-out old wire coat hanger has served me well for years as my "fishing rod.")
You could connect you CB directly to the battery, provided that there's an in-line fuse between the two. However, many find it easier to either tap into an existing fuse terminal with an Add-A-Circuit, or mount an auxillary fuse block to handle the aftermarket add-ons. That fuse block, in turn, can be connected to the battery (preferably via an in-line 50-75 amp automotive circuit breaker).
Or you could install a relay between the battery and the fuse block, so that it will be activated (and deactivated) with the FJ's ignition turned on or off.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
