Thread: Fuses blowing?
Old 02-14-2008, 12:33 PM   #2 (permalink)
Briman42487
Briman42487's Avatar
Member Number: 7204
Re: Fuses blowing?
too small of a fuse? what style fuse are you using? if you are using a AGU style (glass fuse) it may be rated at a higher amperage, but there really isnt enough material there in that style fuse to handle it well. the material heats up since there isnt enough and blows. i would switch the a ANL style fuse if this is the case. if your fuse is indeed large enough, then you have an install problem. retrace every bit of wire. but i think the fuse size is wrong.
Briman42487 is online now   Reply With Quote
