» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 06-02-2006, 01:50 PM   #42 (permalink)
Ridge111
Moderator
Ridge111's Avatar
Member Number: 2612
Re: A-Trac switch install with pics
Ok, after spending 2 hours reading these 2 threads, I have a question. What exactly is the difference between A-TRAC and the standard traction control that is already built in? Then there is the auto LSD. I have 2WD with (here's what is listed on the sticker) VSC, traction control, ABS with EBD and brake assist, A-LSD, and rear diff lock. Without pushing any buttons, I spun the tires in sand the the brake pedal started pulsating; it was braking the spinning wheel to give traction to the non-spinning wheel. So the traction control is already limiting the slip, which makes me wonder what good the LSD button would do for me, and (if I had a 4WD) what more does the A-TRAC do?
Side note: Mine also has the plug for the A-TRAC switch in the dash, even though it's a 2WD. So that may help to confirm to some people that they do wire them up for all the options even if they're not installed, or have no possibility of being installed.
Ridge111 is offline   Reply With Quote
