If you have a 2WD, you can't add A-TRAC. It is esentially your auto LSD that works on the front drive axle too (in the 4WD)
Auto LSD limites the wheelspin on your rear axle and simulates a limited slip differential electronically (transferring power from the wheel that slips to the wheel with grip) TRAC, does the above but cuts throttle as well. Auto-LSD does not cut throttle.
