» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 06-02-2006, 02:55 PM   #44 (permalink)
Ridge111
Moderator
Ridge111's Avatar
Member Number: 2612
Re: A-Trac switch install with pics
RoverGGM previously said:
If you have a 2WD, you can't add A-TRAC. It is esentially your auto LSD that works on the front drive axle too (in the 4WD)
Auto LSD limites the wheelspin on your rear axle and simulates a limited slip differential electronically (transferring power from the wheel that slips to the wheel with grip) TRAC, does the above but cuts throttle as well. Auto-LSD does not cut throttle.
So all this fuss is about that small difference? There must be more to it.
Ridge111 is offline   Reply With Quote
