» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 02-17-2008, 06:28 PM   #224 (permalink)
JoeUser
JoeUser's Avatar
Member Number: 15334
Re: NEW PRODUCT: Ultimate Sway Bar Links
CactusJK previously said: View Post
Not a bad approach. I have only seen the OEM ones pushed to the sides and as a result began to fail. IMO I doubt that when snugged up against a collar that sits higher they will fracture. If so, the bar could only move 3/8" assuming both sides simultaneously fail.
That 3/8" is just about far enough to strike the coil springs, at a minimum (have you noticed how close the link ends are when the sway bar is centered?). I don't want any repositioning, period!
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna Call Sign: KE5WTX; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Metal Tech step sliders; Mini-Me OEM roof rack
JoeUser is offline   Reply With Quote
