» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 02-19-2008, 12:50 AM   #4 (permalink)
Briman42487
Briman42487's Avatar
Member Number: 7204
Re: Using a Line Driver
SteamFire previously said: View Post
I am using it because the Avic-D3's signal is 2 volts. This boosts it significantly.
you dont want to boost it any more than needed. with any modern amp, you will be fine. they probably rate there output voltages in RMS. not peak to peak like a lot of them. output voltage ratings arent regulated by the CEA. there are many different means of rating them just like amplifiers output ratings used to be. now its all on a level playing field so you can compare apples to apples.
Briman42487 is online now   Reply With Quote
